clutch question help plz
Old 08-06-2013, 05:42 PM
jay361's Avatar
Default clutch question help plz
i put a new mast cylinder and slayer holes and still wont go into gear could it be my clutch is no good? everything is in the right order as it should go in
Old 08-07-2013, 07:05 AM
DAVE00's Avatar
Much much more information needed!!!! What car, year, mods, symptoms of the problem, etc..... Put these in here so we can try and help you out.
Old 08-07-2013, 08:48 AM
Village Troll
SS RRR's Avatar
Is this you?
https://ls1tech.com/forums/lt1-lt4-m...l#post17571032
It's a slave cylinder. Not a slayer. Slayer is an evil metal band out of the 80's who loves to hail Satan.
Is the above post the same problem you're posting again? If you know everything is the way it should go it reads like it's time to remove the transmission to see if there is a mechanical problem. At least check to see your clutch fork is seated correctly by first pulling on it to see if it disengages from the throwout bearing and pushing it back in.
Old 08-07-2013, 03:37 PM
johnl361's Avatar
ss RR: yeah, same problem man...i think i need a new pressure plate and clutch disc thats the only thing i have old...ive already bled it and nothing still wont go into gear im ordering one today
Old 08-07-2013, 04:16 PM
johnl361's Avatar
Old 08-10-2013, 06:13 PM
multmigs's Avatar
that video tells me absolutely nothing mhein...
Old 08-10-2013, 07:06 PM
Big Al's Avatar
What happens if you're at a dead stop and you try to put it in first?
Al 86 IROC Toploader Ford, 95 Z28 TH400
Old 08-14-2013, 12:59 AM
johnl361's Avatar
i got it working it was my clutch and flywheel
Old 08-14-2013, 12:08 PM
Village Troll
SS RRR's Avatar
What was wrong?
Old 08-15-2013, 12:12 AM
johnl361's Avatar
didnt want to go into gear at all so i changed the clutch and pressure plate and it worked just need to bleed it cause i have to pump the pedal and then it will go into gear
Quick Reply: clutch question help plz
