Planning on installing a 9 inch rear this winter
9 inch with 4.10 gears. Can I plan on losing 30rwhp on the dyno coming from a 10 bolt with 3.42s??
At least ill be able to launch lol
Still researching / dug up some old threads.
Maybe its not as much as I thought
https://ls1tech.com/forums/gears-axl...in-losses.html
I'd acknowledge a loss from the OEM Dana in my GTO to the 9 inch Ford. But I'd also have to acknowledge my ET going from 7.81 in the 1/8 mile to 7.3 and the latter was on a 60% throttle pass. Whatever the toy you are measuring rwhp with says, it isn't really a loss if you have set everything up right. Just my opinion.
Depends on the driver You tag that much weight on a stock car you are probably going to be able to launch it harder, but can you? I lost 20-30 rwhp and picked up speed. Can't judge your situation
