Details on ls1 swap .
Old 08-13-2013, 02:03 AM
Z28akagluemaker's Avatar
Default Details on ls1 swap .
So I have a 94 z28 and I was just wondering what exactly would have to be done for a ls1 swap to happen . Ik motor mounts most likely a new k member due to the oil pan . After its done it would be intended for daily driving . And harness situation . Possibly what's the cheapest I could look at doing this for
Old 08-13-2013, 02:18 AM
96lt1m6's Avatar
Before you get attacked here i would suggest looking in tge hybrid/conversion section... its 100x easier to search there....
Old 08-13-2013, 02:23 AM
Ok thank you . Figured id try here since maybe some swapper there lt1's to ls1's
Old 08-13-2013, 06:36 AM
jrwilliams95z28's Avatar
I'm considering doing an LS327 build and swapping. Mostly for better weight balance and less weight in general. Plus I might be getting rod Knock I'm not sure, but anyway I digress,
My understanding is you need atleast, but not limited to:
LS engine
Tranny of your choice
Ls k member
Wiring harness and PCM
Ls1 corvette fuel pressure regulator
Motor mounts
And probably a bunch more stuff I can't think of right now
You an pick up a lS327 for like 500 bucks if you look for it. Put 3 grand into and you got a reliable 400+whp car
Old 08-13-2013, 06:37 AM
Plus you can sell you LT1 for about the same at a LS 327
Quick Reply: Details on ls1 swap .
