Another Stock Bottom End In The 8's
Gears are 3.54's IIRC, as far as weight we have never scaled it!
Car made 805whp thru the th400 last week, hoping to turn up the boost to see what she will do!
Great results sir. Lots of inspiration here since I am also building a stock bottom end 5.3 240sx. I will be shooting for a low 10 high 9 sec setup since I will be using a GTO T56.
Would you mind sharing the info on your tire/ wheel spec? Biggest concern I have is traction with our light chassis. Do you mind elaborating on the fuel setup as well?
