Another Stock Bottom End In The 8's
Old Aug 17, 2013 | 12:05 PM
BottleFedZ346's Avatar
Arrow Another Stock Bottom End In The 8's
Well, we have finally got our stock bottom end car in the 8's!!!
Stock bottom 5.3
317's with our porting
Off the shelf Comp. turbo cam
LS9 gaskets
ARP studs
Vic Jr EFI manifold
E85
S480 (17lbs)
TH400
JW 4500 stall
Stock Q45 diff.
Stock axles
S480 (17lbs)
Old Aug 17, 2013 | 12:10 PM
sick_tight's Avatar
damn!
Old Aug 17, 2013 | 01:14 PM
gnx7's Avatar
Awesome! Making getting into the 8's look easy.
What gears in the Q45 diff?
Weight approx with you in it?
With a hood/bumper I'm guessing it'll go faster
Old Aug 17, 2013 | 01:23 PM
chas010's Avatar
I've read several ppl on here say this isn't possible, is this photoshopped?
Old Aug 17, 2013 | 01:27 PM
427zm's Avatar
Wow. That was quick! Nice work!
Old Aug 17, 2013 | 01:43 PM
JAX04's Avatar
What? That going 8s on a stock bottom end isnt?
Old Aug 17, 2013 | 01:47 PM
stock48's Avatar
9 Second Truck Club
Great job congrads!
Old Aug 17, 2013 | 03:55 PM
Thanks!
Gears are 3.54's IIRC, as far as weight we have never scaled it!
Car made 805whp thru the th400 last week, hoping to turn up the boost to see what she will do!
Old Aug 17, 2013 | 04:11 PM
2muchboostNY's Avatar
Great results sir. Lots of inspiration here since I am also building a stock bottom end 5.3 240sx. I will be shooting for a low 10 high 9 sec setup since I will be using a GTO T56.
Would you mind sharing the info on your tire/ wheel spec? Biggest concern I have is traction with our light chassis. Do you mind elaborating on the fuel setup as well?
Old Aug 17, 2013 | 06:09 PM
WheelsUp84z's Avatar
Driver's face in the 2nd pic is probably most accurate!
Old Aug 17, 2013 | 07:37 PM
Blackpanther99's Avatar
Sick man! Congrats!
Old Aug 17, 2013 | 07:59 PM
Pete91's Avatar
Wow that car leaves great!!!! Congrats on the 8's
Old Aug 18, 2013 | 12:59 AM
In for more pix as well.....I know, I am asking for a lot
Old Aug 18, 2013 | 03:06 AM
Hi Volume's Avatar
respect! Those SBE 5.3s amaze me with how much HP they withstand.
Old Aug 18, 2013 | 05:55 AM
Camaro9969's Avatar
Whats this weigh?
Old Aug 18, 2013 | 08:06 AM
2JZFC's Avatar
Congrats!!!! You're hot on my heels.
What happened to the Fox?
Old Aug 18, 2013 | 08:08 AM
samdogmx's Avatar
nice work. post the timeslip.
Old Aug 18, 2013 | 01:40 PM
Spectre86's Avatar
badass run man. did you do rod bolts or anything?
Old Aug 18, 2013 | 02:09 PM
I still have it, getting some new stuff put in the car, i'll be out soon!
Completely stock bottom end, stock rod bolts!
Old Aug 18, 2013 | 04:40 PM
LS1 240sx's Avatar
Congrats brandunnn and the speedzone crew.
