Stumble when methanol kicks on.
Old 08-18-2013, 06:11 PM
Cam72aro's Avatar
Default Stumble when methanol kicks on.
I have my methanol kicking on around 6psi and every time I get a stuffer out of it then it takes off. Where at in the tune can I pull fuel to compensate for this? Thanks for any help, Josh.
Old 08-18-2013, 06:23 PM
MillsMotorvation's Avatar
You can also up the boost time you have it come on, I go until I see KR then back it down a lb or 2. I added a little timing to that spot to help it, that worked for me. I got 3spray nozzels, so it sprays a lot in mine. Try either one, and see what you like, the PCM sees the added fuel and pulls it to keep AFR in check, so pulling fuel may throw your tune off.
Old 08-18-2013, 06:24 PM
jjcamaro02's Avatar
I pull fuel out of power enrichment (EQ ratio). What is you AFR when the meth kicks in?
Old 08-18-2013, 06:40 PM
Cam72aro's Avatar
On the wideband its around 11.5 then of course when it kicks on it drops because of the stumble, but back to low 11's after that. I pulled a little out of the power enrichment and boost enrichment tables and a little out of the main ve as well. I also added 2 degrees of timing in these cells. I am gonna take it out and make a couple of hits and see what it does.
Old 08-18-2013, 06:53 PM
rotary1307cc's Avatar
How much u spraying? Non progressive?
Old 08-18-2013, 06:59 PM
Cam72aro's Avatar
Cm12 nozzle 12gph or about 1200cc a minute. It's a cooling mist non progressive system.
Old 08-18-2013, 07:12 PM
Glad to see your driving it a little.
Old 08-18-2013, 07:22 PM
jjcamaro02's Avatar
I don't change anything in the VE table. Adding timing will help to lean it out make small changes. I would concentrate more on the fuel first.
Old 08-18-2013, 09:49 PM
Cam72aro's Avatar
I got it back at my house for the time being. The project car I had been working on for a customer is at the body shop so I have it back and doing some things to it. I made some changes to timing, fuel and methanol on time and F************************* this car will hurt you now. I put a small shot of nitrous on it. Turns on at 3000rpms and off at 4500rpms. 13psi 16 degrees of timing. I put some 325 50 15's on the back and it hooks hard and puts you in the seat.
I made some small fuel and timing changes and now it will hurt you it hits so hard. No more stumble. Thanks for the help.
Old 08-18-2013, 09:51 PM
LS1Tech Sponsor
Slowhawk's Avatar
Upgrade to a controller that ramps it in. A lot easier to tune.
Old 08-18-2013, 09:59 PM
Cam72aro's Avatar
Next on the list, lol. . . Just happy to get the stumble out of it.
Old 08-19-2013, 02:11 AM
stangtrader's Avatar
I just delt with the same issue but was way richer and fixed it by cleaning up my ve table a lot . now im wondering if I should change that
Old 08-19-2013, 03:07 PM
Glad to see you got it working! I try to bring my meth in as late as I can so I can build more boost off the line without the meth choking the car. I cant get my car to hook at all I have 295/55/15(27) Will your tire size fit on stock car, or your car been tubbed? How tall is a 325/50/15?
Old 08-19-2013, 07:12 PM
Cam72aro's Avatar
It's on stock wheel wells. It requires a bfh mod and rolling the outers. They are 28" tall.
Old 08-19-2013, 08:55 PM
Ok, I think bfh means big f**king hammer? LOL
Old 08-19-2013, 09:52 PM
Cam72aro's Avatar
It does Bernard. The front of the inner fender requires some massaging.
Old 08-19-2013, 10:22 PM
mrstepheneades's Avatar
I have never experienced stumble and I got mine coming in at 7psi. Mine is not progressive so it comes on wide open with twin 10 pound nozzles spraying pure meth. Afr drops from 11.0 to 10.2 and holds 10.2 till I let out. Drowning it cause I'm 16 psi and stock bottom 2000 ls1. Lol
Quick Reply: Stumble when methanol kicks on.
