Pegged the Dyno and Picked Up 300rwhp with LJMS CAM
Big thanks to John @LJMS. After getting the New FI 5533-94 ETR HO I was in desperate need of a different cam and some more compression. I tore it apart an upgraded rods to some callies ultra billet and callies crank. Called John up and he worked the magic, speced an amazing hyd roller grind. I upped the comression a point and assembled it all.
Got it all together and over to the dyno today. It only took 20lbs of boost to peg the dyno. I made 1200rwhp and by calculations on the dyno it would of been 1350+. Either way I picked up a solid 250-300 rwhp on low boost for this turbo. Im very happy and anxious to hit the track on friday!
Again much thanks to LilJohn motorsports for making dreams come true and Brian @ Dyno tune motorsports as always for the tune work. I have no doubt its making 1400-1500 at the crank at just 20 lbs and it would start pouring power on with more boost!
Video and graph
Video and graph
I don't think he will push water at this level, I agree with the 1400hp remark, I think the fact that you're running a larger charger and less boost helps with cylinder pressure.
congrats on the gains. i can see it because you had a big a## cam in there before that must have been awful for power and 2. ive seen increased compression do some amazing things on turbo builds.
question -why is the car on the dyno red? didnt you have the car plastidipped?
thanks guys 25+ psi scares me
its still a 370inch with a tick over 10:1. Nothing special here if you have the time and a couple nickles to build it... it can be duplicated
I peeled the plasti dip about a month ago, it wasnt for me or the car...cool experiment thats all. Hopefully getting the car painted this winter.
Changing the oil and going over some things on the car today and getting ready for tomorrow. Weather has been nice up here with good air quality, if I get it to stick on a soft launch here at my home track it should be a good run.
