Narrow Band Placement On Truck Manfiold Kit
Old 09-07-2013, 12:17 PM
Restricted User
Zero4488's Avatar
Default Narrow Band Placement On Truck Manfiold Kit
Just curious to see what kind of results you guys are having with the narrow bands pre-turbo. I'm working on a car right now where they read great, but once you bring it into boost a few times one of the sensors fail and I'll see split fuel trims. I am curious if this is just the sign of a complete failure on it's way or maybe it has to do with the narrow band placement. I'd like to get some input before we just replace the sensors.
-Dave
Old 09-07-2013, 12:21 PM
Cam72aro's Avatar
I run 5th gen camaro manifolds, but placement is preturbo, I have zero problems as others do the same. What brand, age of sensors, etc?
Old 09-07-2013, 12:22 PM
ls1_chevelle's Avatar
where is the placement? Mine are right before the turbo and about 4" downstream from the last primary tube. Only issue I had was with leaded fuel and a rich tune.
Old 09-07-2013, 12:39 PM
Restricted User
Zero4488's Avatar
These are located right after the truck manifolds, It may just be a sensor not responding well to the heat. Not sure on the brand, looking into Delco or NTK for a replacement.
Old 09-07-2013, 01:00 PM
Tally TransAm's Avatar
i run narrow bands in or right after the manifolds on multiple cars without issue.
Quick Reply: Narrow Band Placement On Truck Manfiold Kit
