Sprung vs. UN-Sprung Clutch Twin Disc.?!?!?
Old 09-12-2013, 07:53 PM
1999Firehawkls7's Avatar
Default Sprung vs. UN-Sprung Clutch Twin Disc.?!?!?
Like the Title says......
Im in the market for a nice Twin Disc Clutch for my C5 Zo6 (Its a toss up between the McLeod RST/RXT and the Ls9R Katech clutch)
Only thing making me wanna spend double the cash on a Ls9 Clutch is that its a Sprung Disc type and by the Pics Neither the RST or the RXT from Mcleod appear to be Sprung.
I've seen a few post from guys saying that w a UN-Sprung Disc. they have had the input shaft splines start to twist from the hard engaugement, anyone got anymore info on this?
Also seeing that Twin Disc Clutchs dont last as long as Single Disc because they build up double the heat? This is a bummer to read as well, how long will they last w just general street wear and tear?
Thx!
Old 09-12-2013, 08:06 PM
2 Stroke Racer's Avatar
Thx!
Katech clutch is overpriced junk IMO.
Go with the McLeod.
Old 09-12-2013, 08:09 PM
Go with the McLeod.
Any reason behind this?!
Old 09-12-2013, 08:13 PM
The install instructions for one, heating the flywheel up to a
Certain temp before torquing.
I also know they don't work well for drag racing.
I know of one that was slipping with a couple thousand miles
Of street driving.
Old 09-12-2013, 08:38 PM
^Good to know!
This is the first I've herd a Negative about the Ls9 Clutch but havnt herd much on it at all to be honest w ya
and to have to heat up the flywheel before installing?! Is this just to immitate the temps its going to see after its warmed up as if it were in a car? Never had to do that w any flywheel
Old 09-13-2013, 08:27 AM
SPEC-01's Avatar
At the end of the day an LS9 kit is still a stock clutch. From experience, there are plenty of ZR1 guys that move away from these units to our Super-Twins. The idea that clutch life is inherently limited when using a twin-disc seems to be circulating in this forum and, though everyone is entitled to their own opinion, this isn't necessarily the case. It all comes down to usage. I have plenty of customers with thousands and thousands of miles on multi-disc clutches. At any rate, We offer 4 different Super-Twin options. I have provided a link to the kits below. Take a look and let me know if you have any further questions. Thanks!
http://www.specclutch.com/cars/Chevy...002/Super_Twin
Old 09-13-2013, 05:37 PM
I still would like an answer on this> "I've seen a few post from guys saying that w a UN-Sprung Disc. they have had the input shaft splines start to twist from the hard engaugement, anyone got anymore info on this?"
Old 09-13-2013, 05:46 PM
Italianjoe1's Avatar
From the 350Z world, un-sprung clutches don't damage the transmission but they are brutal on the street. I have a sprung OS Gieken twin in my Z and it's ok to drive on the street but the engagement is about as harsh as you would want in a daily driven car. Very sharp engagement even with the springs.
Old 09-13-2013, 05:59 PM
HioSSilver's Avatar
Sprung clutches are for girls.
Old 09-13-2013, 06:15 PM
^ Glad you think that Sir!.......Anyways...I want whats not going to break in put shaft or twist the splines....building a nice Driver car not a max effort car
Old 09-13-2013, 06:38 PM
HioSSilver's Avatar
I've been running a none sprung clutch for 7yrs......in dd. Who the hell told you they twist splines or break input shafts?? You shouldn't listen to that guy.
Old 09-14-2013, 02:18 PM
Ppl on the Corvette Forum
Old 09-14-2013, 02:51 PM
thirdgenbum's Avatar
how much power? if it's a driver, non-max effort car, why not look at some of the nice single disc clutches available?
Old 09-16-2013, 04:41 PM
To get a Single Disc to hold w out slipping ya need a Over the Top Pressure plate and that makes it a pain to drive w a stiff clutch pedal
Twin Disc will have a light, stock pedal feel and more holding power = win, win!!
Old 09-16-2013, 06:28 PM
just expensive i guess. lots of guys putting some OK power down through the monster level 2. but you didn't say anything about the power output of the combo, so i don't want to suggest too little of clutch.
Old 09-16-2013, 07:04 PM
SNLPerformance's Avatar
I run unsprung hub in my C5 for faster shifts as it's lighter, springs do help with dampening engagement though and the driveline in a corvette tranfers harmonics more so than others especially if using solid mounts.
Old 09-17-2013, 12:22 PM
BALLSS's Avatar
if you can find a quality (McLeod, Monster, SPEC) twin that fits your application, get sprung hub, even if just one disc is sprung.
For me, LT1, McLeod is the only offering for a twin and it has solid hubs. To my surprise street maners are very smooth.
Old 09-18-2013, 11:31 AM
SPEC-01's Avatar
Running a rigid hub will not inherently cause spline damage.
Old 09-18-2013, 12:52 PM
Cars gonna be at 500whp NA, MIGHT spray it w a 150 shot down the rd <not sure yet
Old 09-18-2013, 01:12 PM
SPEC-01's Avatar
Based on your claimed number you wouldn't have to have a Twin-Disc. Our Stage 3+ would easily handle this and provide great street friendly manners and easy effort. Of course our SST Super-Twin would be a great option too!
Quick Reply: Sprung vs. UN-Sprung Clutch Twin Disc.?!?!?
