what degree do you guys mount the engine?
I'm ready to weld my motor mounts in a 40 ford. I noticed in pictures of stock silverados the back of the valve cover is lower than the front. Is it about 5 degrees?
The degree at which allows you to acheive proper U-joint working angles is what you are shooting for here. Settling on some arbatrary degree between 3 and 5 degrees is in no way going to tell you what those are, you need to get under your vehicle with it sitting at its final ride height/stance and start taking pinion and engine inclination measurements to determine where it needs to be. The engine inclination angle and pinion angle should match within 1/2 a degree (unless you are building a dedicated drag race car that can benfit from a few more degrees of static pinion down angle) and the U-joint working angles should be more than 1/2 a degree and less than 3 degrees for proper joint operation and designed lifecycle.
The general rule of thumb is all motors are placed at a 3 degree angle down. The rearend 3 degrees up. Measurements should be taken on level ground. You should be not be off more than 1 degree.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
As far as correct driveline angle.. it is more than just setting the engine at 3-5 degree.. the engine/trans angle need to work along with the rear end pinion angle (as Toddoky stated). If you are un-aware with this, suggest you do a Google search on "Correct Driveline Angle". You will find many articles on it.
Tip.. if your car is lowered and you have a hard time getting under the car.. the engine / trans angle can be checked by measuring the crank stout / Balancer as it is in direct line with the output of the Trans output shaft (which is where everyone measures).
My reason for this spec is that you have to start somewhere. I have always set the motor and transmission at a specific spec and adjusted pinion angle accordingly. Again, you have to start somewhere. Eric L
The closer you can get to 3 degrees to use as your "starting point" as you say the better. Trust me on this one, you don't want to start at 5 degrees engine inclination angle as some rear pinions are a P.I.T.A to get more than 1 or 2 degrees of adjustment out of them.
That adjustment will allow you to get the U-joint angles the same within 1/2 a degree as you should, but you still need to ensure the working angles of the U-joints will be at least 1/2 a degree and less than 3 degrees. Proceed with determination to measure all these angles BEFORE you do any final welding of your mounts or you may end up spewing a few curse words before your swap is done.
