Carburetor Recommendation
hello people, I have a Gen III 5.3 LS with carbureted 10:1 compression, this engine is completely stock, rods and pistons have Gen IV, and 706 heads
my question is: which carb do you recommend me that this engine than good with an edelbrock intake manifold of single plane
LS1Tech Sponsor
Received 1,130 Likes
The Chevrolet Performance LS 327 engine is very similar to the specs you noted and they recommend a 770 Holley Street Avenger Carburetor.
that advantage has holley street avenger holley 770 of the holley 750 Vacum secundary model 4160?
Seems like a 650 is a pretty common carb sized for stock 5.3's. The smaller carb might be a little easier to tune if you are new to carbs.
As for single or dual plane it really depends on the car weight, gearing and intended use. If you have a stock truck cam and valve springs then dual plane is without question the way to go. The truck stuff runs out of air over 5000 RPM. If you have any plans to upgrade cam and springs than the single plane might be the better choice depending upon gearing and car weight.
LS1Tech Sponsor
The Street Avenger carburetors are more performance oriented and are actuall based on a 4150 carburetor, but with the addition of a vacuum secondary to be more street friendly. The Street Avenger also contains Holley's newer fuel metering system and easier adjustment of needle and seat along with the quick change secondary spring.
Depends on use IMO......
Street 650-750 VS...650 for a cruiser (best MPG and throttle response) 750 for hot street (street/strip action)
Strip 650-750 DP... 650 with the stock cam and 750 for the upgraded cam.
