What's a good aftermarket oil pan set up
Old 09-17-2013, 09:19 AM
Wesley Sumner's Avatar
Default What's a good aftermarket oil pan set up
Seems like aftermarket oil pans are hard for find. Id like to find a 7qt. racing oil pan that includes everything and would clear under a 2002 F Body Trans Am. Its a 6.0 Iron block if that makes any difference.
Old 09-17-2013, 09:25 AM
2muchboostNY's Avatar
Not sure if you can use front sump (complete noob here) but the Canton unit seems to be a great option.
http://www.enjukuracing.com/products...-LS1-Swap.html
Old 09-17-2013, 10:03 AM
Black Sunshine/ 00SS's Avatar
Most, if not all require you to purchase their pick up tube and windage tray. Some also require you to relocate the oil filter. I understand the advantage of relocation, but added up, you've got almost a G into the setup. I'm liking the moroso setup, but would be happy with an upgraded pan that uses the stock windage and pickup tube.
Old 09-17-2013, 12:44 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
If oil starvation is your concern, check out this baffle system for a stock pan:
http://www.improvedracing.com/oil-pa...ffle-p-30.html
Granted, you don't get the extra capacity you're after, but it does help with starvation.
Old 09-17-2013, 01:07 PM
87silverbullet's Avatar
Autokraft makes probably the most easy of all the aftermarket pans.
http://www.autokraft.org/products/
Scroll down once you click on it.
The moroso unit is popular and it works and can be had for between 6-700
The canton unit works too but there is all the stuff such as the billet oil filter mount which don't fit if you have bigger than 1 3/4 headers.
You will end up going to the relocation setup eventually if you use the Canton oil pan
Old 09-17-2013, 04:21 PM
samdogmx's Avatar
autokraft is a nice piece and probably the cheapest option too.
Old 09-18-2013, 09:36 AM
You do know you posted a link for a pan to swap and LS1 into a 240sx.
Quick Reply: What's a good aftermarket oil pan set up
