trans questions
Old 10-01-2013, 10:27 AM
davidhOK's Avatar
Default trans questions
If I buy a truck motor 4.8, 5.3. 6.0, etc will the electronics of the 700r be compatible with the motor? I know one bolt is won't be able to be used in bellhousing. But with a simple aftermarket harness will everything work well?
Or should I avoid the hassle and just get a 4l60E?
I say this because my project was originally going to use a tbi/700R from a 92 caprice but have decided against it now and go LS motor. This will go in an old 50's truck. thanks
Old 10-01-2013, 10:34 AM
SKEETS63IMPALA's Avatar
I don't think any 700r4s were electronically controlled, it should shift by using a TV cable. When they switched to electronics, it was changed to the 4l60e.
Old 10-01-2013, 10:40 AM
davidhOK's Avatar
Yes I think you are right the only electronic part is the lock up converter .
Old 10-01-2013, 11:22 AM
71403's Avatar
Yes - easier and a better result.
Old 10-02-2013, 02:30 PM
vhehn's Avatar
except if you want a speedo.
Old 10-02-2013, 02:41 PM
Daz
Daz's Avatar
I'm sure there is an adapter out there. Plus there is always GPS speedo's !
Old 10-02-2013, 08:45 PM
vhehn's Avatar
yes, there are adapters but they cost as much as a used trans.
Quick Reply: trans questions
