WTT/Sell 94 383cid/T56 Z28
Year: 1994
Make: Chevrolet
Model: Camaro
Price: $8000
Mileage: 216
Private or Dealer Listing: Private Listing
Location (State): OH
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
Motor: Forged 383 CID stroker / 11.5:1 compression / LE2 heads / full roller / xfi292 Cam / Professionally built and balanced by M&M in Delaware Ohio ( rings are file fit for NOS) -- Installed by Bauerle Automotive in Delaware
Induction & Charging: Naturally Aspirated / LT4 Intake / 42lb SVT injectors / Adjustable regulator / Performance Engineering TB (ported w/ an IAC bleed hole) / Walbro 255 FP / functional RamAir / Power Master 220A Alt / BBK & March pulleys / AC delete plate
Ignition: MSD everything / super conductor wires / coil / 6MT box / GM Performance OPTI
Cooling: BeCOOL radiator / HyperTech 165 thermostat / Meziere electric pump / all new hoses / Redline coolant / Twin electric fans
Drive Train: Ram HD clutch / Fidanza flywheel / B&M Ripper / Driveline ONE built shaft with Dana Spicer U-joints / 4:11 Richmond rear end
Exhaust: Full length Race headers fully wrapped / 2.5" X-pipe / true duals with Moroso Spiral Flows
Suspension: UMI -- Frame ties / control arms / Panhard rod / front and rear sway bars / strut tower brace / Energy suspension urethane mounts (trans, sway bars, motor, torque arm) / KYB AGX shocks / New Rack & Pinion
Interior: Auto Meter Ultra-Lite gauges / Power seats / stock trim, but have pulled 400lbs out of the car
Controls: All new GM sensors nose to tail / LT4 Knock module in the ECM / OBD1
Software: The car will come with a Dell Latitude laptop for tuning / ALDL communication cable / TunerCATS / DataMasters TTS
Tuning: Initial startup & break in on the Dyno at PickUps Plus in Delaware OH. Race tuning by Bryan Herter
Spare parts included: OBD1 ECM / Injection & Communication harness / Water Pump / Walbro 255 FP / Coil / 8 injectors
YouTube link of the car at idle.
If you're interested and want to know more, or have a possible trade / cash offer, you can email at j_lewis79@live.com
