need help asap! 305/35r19
Old 10-04-2013, 08:52 PM
TRANSAM11's Avatar
Default need help asap! 305/35r19
I recently bought a set of nitto nto5r tires and am wondering if they are going to fit on my transam ws6 the size is 305-35-19 on the rear and 275-35-19 on the front... anybody ever run this size? or does anybody know if these will fit without issues I know I might have to roll the rears but other then that I have no clue ... so any help would be amazing ...thanks guys,sorry im a rookie at this
Old 10-04-2013, 11:29 PM
DemonicZ's Avatar
take a look at the sticky at the top of the thread section. and tire size doesn't matter as much as specs on the wheel.. offset, back space. assuming these are made for F-bodies you'll be fine with BFH and fender rolling. if you're lowered you'll need LCA relocation brackets and adjustable panhard bar.
Old 10-11-2013, 02:55 PM
ReggieLSx's Avatar
What size are the wheels?
Old 10-14-2013, 02:09 PM
SSCamaro99_3's Avatar
NT-05R's will not be ideal for the front of the car.
Old 10-14-2013, 05:03 PM
VetteRedLS6Z28's Avatar
Those Nittos for the front of the car is a bad idea. Get some 555r's for the front instead
Old 10-15-2013, 02:22 PM
Unless you are talking about RII's, probably won't be much better. The softer sidewalls of drag radials are going to make them lazy on cornering. i was not much of a fan when I just had drag radials in the back. Did the job getting the car moving, but did not like the cornering.
Old 10-29-2013, 09:40 PM
TRANSAM11's Avatar
they are going to be 19 inch ccw sp500 wheels and no the fronts are not going to be radials they are going to be the 555's ... my only concern is clearance since the car is lowerd with eibach sportline springs ..
Quick Reply: need help asap! 305/35r19
