need help asap! 305/35r19
I recently bought a set of nitto nto5r tires and am wondering if they are going to fit on my transam ws6 the size is 305-35-19 on the rear and 275-35-19 on the front... anybody ever run this size? or does anybody know if these will fit without issues I know I might have to roll the rears but other then that I have no clue ... so any help would be amazing ...thanks guys,sorry im a rookie at this
take a look at the sticky at the top of the thread section. and tire size doesn't matter as much as specs on the wheel.. offset, back space. assuming these are made for F-bodies you'll be fine with BFH and fender rolling. if you're lowered you'll need LCA relocation brackets and adjustable panhard bar.
Unless you are talking about RII's, probably won't be much better. The softer sidewalls of drag radials are going to make them lazy on cornering. i was not much of a fan when I just had drag radials in the back. Did the job getting the car moving, but did not like the cornering.
they are going to be 19 inch ccw sp500 wheels and no the fronts are not going to be radials they are going to be the 555's ... my only concern is clearance since the car is lowerd with eibach sportline springs ..
