Procharger BOV mounting HELP
Old 10-05-2013, 10:50 AM
KY Nova's Avatar
Default Procharger BOV mounting HELP
Does it matter or make any performance difference if you mount the Procharger Big Red BOV with the standard length supplied piece of tube or a custom tube that has a 90* and is 18" long? I
Reason is, I don't have hardly any room to mount this thing.
Below is the tight spot that I could use the supplied mounting tube. The radiator is about 1/2" away from the side you can't see.
The pick below shows a spot with a little more room and I wanted to make a bracket to the blower bracket to help support it. Are there any problems with mounting it upside down also?
Thanks for the help
Allen
Quick Reply: Procharger BOV mounting HELP
