Chirping sound coming from bellhousing area
Or atleast I think it is....chirp chirp chirp....gets faster / slower with engine RPM. Just put a Monster stage 3 in it at the beginning of the year. Thinking maybe the pilot bushing or throwout bearing? Doesn't change sound by engaging / disengaging the clutch though....
It does sound like a bearing issue. Generally speaking, if this were relative to the release bearing, the noise would change when the pedal is depressed. You can certainly check both when the trans is down but my guess is that your sound is coming from the pilot.
With that many miles, it really is time for a new bearing. You really should replace them whenever you install a new clutch. I have these on the shelf if you need them. Just let me know!!
