LT1 Shutters and CEL
Old 10-19-2013, 03:03 PM
dabeav3's Avatar
Default LT1 Shutters and CEL
My 95 TA had the check engine light come on a while back and today it started shuttering while driving and running rough (didn't think I would make it home). Put the scanner on it and got like 50 codes. Disconnected the battery and can't seem to make the codes go away. Just turn 100k so probably need to do a full tune up but want to address the issue and not just throw parts at it. Probably the Opti-spark but am looking for ideas. Thanks.
Old 10-19-2013, 04:12 PM
The Outlaw Kid's Avatar
What were some of the codes?
Old 10-19-2013, 04:37 PM
dabeav3's Avatar
I didn't write them down. Unhooked the battery to see if I could get all the codes erased and start from new. If I can't get the codes to erase I guess the PCM might be bad. Thanks
Old 10-19-2013, 04:40 PM
shbox's Avatar
Might be the scanner you are using. Some are kooky.
Old 10-22-2013, 10:33 PM
dabeav3's Avatar
tried a different scanner with the same results. Getting somewhere around 50 codes split between current and memory. If I rescan I get a similar number of codes some different some the same. Still can't get the codes to erase after leaving the battery unhooked for two days. Took the PCM out and cleaned the connectors, grounds and hot leads and made no difference. Trouble shot the knock sensor and eveything checked out fine. Starting to think the PCM is bad. So what is the "flashing" a new one entail? Took the access cover off the PCM and there was a little white "box" plugged in. Is that the "same" as the old chip for prior installations and would it be a matter of swapping it into a new PCM rather than "flashing" it?? Car still shutters/hesitates/misses during cruising and seems worse after it has warmed up. thanks,
Old 10-22-2013, 11:09 PM
shbox's Avatar
Possibly is a bad PCM (or maybe a grounding or power issue?). Can't imagine that many codes at one time. The little white box is the knock module. Flashing takes a programmer or a laptop/PC, cable, software and a tune.
Old 10-23-2013, 06:57 AM
dabeav3's Avatar
Thanks much for the inputs. I cleaned all the connectors while I had the PCM out and cleaned the ground/power inputs as well so I guess its time to try a PCM.
Old 10-23-2013, 07:35 AM
9-Second Club
Ed Wright's Avatar
If you know somebody with an LT1 try plugging it into their car and check for codes. Don't even need to start it. Lots of PCMs get replaced for no reason. Also plug the other PCM into your car and check for codes.
Old 10-23-2013, 10:59 AM
KyleW707's Avatar
When my temp sensor was bad, my car was throwing around 20 codes, replaced it and all went away. Not saying that's your problem, but it's worth a shot before swapping pcm's
Old 10-23-2013, 11:08 AM
pillarpod's Avatar
50 codes is a lot, so how many do you have if you just look at "current" codes?
Old 10-23-2013, 03:29 PM
dabeav3's Avatar
about half of the codes are current and half memory. 13, 16, 28, 32, 37, 41, 41,43,44,45,46,47,53,55,58, 5961,63,64,65,75,83 current. 13,14,18,23,25,26,28,44,48,55,58,61,75,79,81,82,83 ,85 memory. even get 39,57,19,35,49,56,62 etc. that aren't even effective for me car. seems very weird to me that I can't erase them either so is why I was thinking the PCM. so where is the best place to get a new or used PCM flashed? thanks as always.
Old 10-24-2013, 12:54 PM
ahritchie's Avatar
Is it modded or stock? If you have mods, I'd get PCM for less or some other mail order tuner reflash it for around $100 custom for your setup. Otherwise, I'd buy a used PCM off craigslist or a junkyard, or better yet find another LT1 owner nice enough to let them swap their PCM just to eliminate it as a cause.
Old 10-24-2013, 02:22 PM
dabeav3's Avatar
Unfortunately don't have anyone around with an F-body like mine (everyone wants a Toyota or Honda these days) that I can swap with. So for a used unit, does it have to be a 94 or 95 F-body with a manual trans PCM for things to work right???
Old 01-16-2014, 04:19 PM
dabeav3's Avatar
Default update
OK, got a different PCM and got exactly the same results. CEL comes on and the car shutters while driving. Ran a scan and am still getting 50+ codes either present or stored using Shoeboxe's hook up chart. Would the opti spark going bad generate so many codes? Any suggestions/ideas would be greatly appreciated.
Old 01-16-2014, 05:01 PM
ahritchie's Avatar
I already replied to your other thread....opti is toast, get a GM one or MSD
EXCELLENT article on the intricacies on opti failures:
http://www.gmhightechperformance.com...ing_modifying/
Old 01-16-2014, 07:14 PM
fbody_brian's Avatar
Check your battery connections, make sure your grounds are tight!
Old 01-16-2014, 11:17 PM
dabeav3's Avatar
Yeah I checked out all the grounds and cleaned all the connections some time ago with no help. Its got right at 100k on it so I guess its time for an optispark, water pump and full tune up.
Quick Reply: LT1 Shutters and CEL
