trans wiring
Old 10-20-2013, 03:32 PM
31-5window's Avatar
Default trans wiring
Looking for wiring info I am doing a swap I have a 2005 6.0 4L80E and I have a three wires that are on fuse block connector that I don't know what to do with. Can any help
Old 10-21-2013, 02:44 AM
ls1nova71's Avatar
Going to need more info than that. Like what connector? What wire colors?
Old 10-21-2013, 12:52 PM
31-5window's Avatar
It is a round gray connector that is on the trans. light green, dark green, gray all three wires are connected to fuse block connector.
Old 10-21-2013, 04:28 PM
31-5window's Avatar
Aright the wires are D3 light green [park neutral position park signal] not sure what to do with it sounds like it go's to cluster. F11 dark green [park/neutral start switch] not sure what to with this ether. I was assuming I could leave the neutral safety switch on the trans and use it? A11 [trailer back up lamp supply voltage] I think this would be for back up lamps?
Thanks,John
Old 10-22-2013, 09:27 AM
ls1nova71's Avatar
Sounds like you pretty much got it figured out. If you want to use the NSS, you only need the dark green and a pink wire. You would run your start wire from the ignition switch to the pink wire in the 'E' terminal of the NSS connector, then the dark green wire in 'G' would go to the starter relay on terminal 85. 86 would go to ground, 30 would go to the battery and 87 would go to the starter solenoid.
Old 10-23-2013, 07:31 PM
31-5window's Avatar
Cool thank you.
Quick Reply: trans wiring
