Rockford Fosgate 700x 4 channel amp
Category: Audio/Video/Electronics
Price: $140
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): WA
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Non-LS Part
2. Specs: Ive seen the birthsheet but I dont have access to it. It said 920 watts
87.5 watts RMS x 4 at 4 ohms
175 watts RMS x 4 at 2 ohms
350 watts RMS x 2 at 4 ohms in bridged mode
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier (see "Detailed Info" for wiring recommendations)
2-, 3-, or 4-channel output
Tri-way capable (Tri-Way crossover required)
front and rear high-pass/low-pass crossovers (variable 50-210 Hz, 12 dB/octave)
MOSFET power supply and output devices
Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
Punch Bass boosts bass up to 18 dB at 45 Hz (separate controls for front and rear channels)
dimensions: 18-1/2"W (14-13/16" without endcaps) x 2-7/16"H x 9-7/8"D
3. Description/Condition: Looks pretty good . A little dusty missing endcaps and the logo but thats reflected in the price. Currently running everything in my car and its more than enough. I had this runing my front and a jl audio sub and it was loud as hell. Sat in my top storage too
4. Price: : 125 plus ship. I can be reached here or texted 2533593715 . I work so if I don't answer immediately i'm at work or busy.
5. Pictures:
