01 GT with 5.3/Th350 swap
Old 10-25-2013, 10:28 AM
01GT5.3's Avatar
I am new to this site and posting stuff, also to the whole LS swap thing so Opinions are needed. I decided I would start a Thread on my budget project that I've been working on. It's an 01 Mustang GT that I've had for a couple of years. I started the swap after the 4.6 2valve in it kept messing up. I sold all the 2v engine and trans stuff and bought a junkyard 5.3 I already had the Th350 from an S-10 project that I sold. I've got most of the major things to put it together I just lack exhaust, wiring it up which I've already bought a PSI harness, and finish hooking everything else up like fuel system and some odd and end things
01 GT with 5.3/Th350 swap-forumrunner_20131025_112752.png
01 GT with 5.3/Th350 swap-forumrunner_20131025_112137.jpg
01 GT with 5.3/Th350 swap-forumrunner_20131025_112344.png
Attached Thumbnails 01 GT with 5.3/Th350 swap-forumrunner_20131025_112410.png
Old 10-26-2013, 04:44 PM
99MUSTANG5.3L's Avatar
Welcome to the site. What k member did you use? An AJE k member will open up alot of room for headers.
Old 10-26-2013, 05:34 PM
tired2valve's Avatar
Aje k member and mounts. I ran a new fuel line from the tank to the rail. Used the vette filter regulator where the stock filter was. Ran the return back into the tank.
Old 10-27-2013, 12:51 AM
01GT5.3's Avatar
I have the Granatelli k-member, it was put in when it had the 4.6 in it still, I made my own adapter plates to bolt the motor to the 4.6 mounts. I'm running the truck intake and all to begin with so I'm just gonna run the regulator on the fuel rails until I change the intake. I'm gonna try to find some new camaro manifolds to run on it cause I'm thinking about slapping a turbo on it and don't see any need in spending 6-700 dollars on headers if I decide to go turbo
Old 11-26-2013, 10:00 PM
01GT5.3's Avatar
These are a few pics of the more completed engine bay with a few pics of the 2010 & up Camaro manifolds, the driver side is not as close to the steering shaft as it looks, I can put my hand in between the shaft and manifold
01 GT with 5.3/Th350 swap-forumrunner_20131126_224741.jpg
01 GT with 5.3/Th350 swap-forumrunner_20131126_224846.png
01 GT with 5.3/Th350 swap-forumrunner_20131126_225151.png
01 GT with 5.3/Th350 swap-forumrunner_20131126_225543.png
01 GT with 5.3/Th350 swap-forumrunner_20131126_225623.png
Attached Thumbnails 01 GT with 5.3/Th350 swap-forumrunner_20131126_224314.jpg   01 GT with 5.3/Th350 swap-forumrunner_20131126_224757.png   01 GT with 5.3/Th350 swap-forumrunner_20131126_225209.png
Old 11-27-2015, 04:38 PM
Pat128's Avatar
Default Hello how you doing
I also have a 01 mustang get and wanted to know the basics on rough estimate how much does it cost to do the ls swap please write back when ever you can
Quick Reply: 01 GT with 5.3/Th350 swap
