buying valve train stuff
Old 10-29-2013, 08:20 PM
oscs's Avatar
Default buying valve train stuff
quick overview guys:
LQ4
317's
228R 114LSA .590/.590 cam
twin T61's
Parts list:
ARP head studs
lunati .660 dual springs
LS9 head gasket
what size push rods should i run? how do you figure the length out for that matter? since Im going to be in there if i figure why not swap the lifters.. any affordable recommendations?
Old 10-29-2013, 10:43 PM
Calypso's Avatar
You should measure with the pushrod checker tool, but I used the standard 7.4" COMP Cams (7638-16) with LS9 gaskets and they were fine. Stock LS7 lifters are standard and can be bought anywhere.
Old 10-30-2013, 06:42 AM
oscs's Avatar
You running 317's ?
Old 10-30-2013, 09:11 AM
Calypso's Avatar
Yep. Untouched aside from lunati dual springs.
Old 10-30-2013, 10:01 AM
oscs's Avatar
Excellent, im running the same springs too. Ill order the 7.400 today thanks for the help.
Old 10-30-2013, 04:13 PM
oscs's Avatar
anyone have a P/N for the right ARP head studs with 317 heads? motor is a 01 lq4
Quick Reply: buying valve train stuff
