*HUGE* Shop sale - Tons of parts
Category: Accessories
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): GA
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
I will add more to the list as we dig them up. November 14th - 9am ET - Post has been updated with what's been sold
*New* 2 sets of Trick Flow .650 Valve springs, just springs only. No hardware. Fits ALL LSX engines - $50/ea set
*NEW* Powdercoated (red) front LSX timing cover, Will fit an LSX application that does not have a front mounted cam sensor. Fits most truck engines also, also has brand new front crank seal already install, will come with new cover gasket also - $50
*NEW* JP Performance adjustable Double roller timing sets. We have sets for ALL the LSX engines - $70 each
*NEW* 2011+ Chevy/GMC Silverado/Sierra K&N air filter, new in the box - $25
*NEW* Comp LSL lobe 244/248 .625/.625 112+4 Camshaft. Fits all LSX engines - $275
*NEW* Comp LSL Lobe big cube 247/263 .629/.629 113+4. Fits all large c.i. LSX engines - $250
*USED* Comp LSL Lobe 235/243 .625/.630 113+4, Low mileage. Fits all LSX engines - $250
*NEW* Cam Motion custom spec'd Spartan camshaft, 232/240 .630/.630 114+4 on Spartan lobes - $300
*NEW* Stainless steel SLP "Loudmouth" resonator. This is the LM1 - $50
*NEW* Edlebrock Torque arm, 1993-2002 Camaro/Firebird - $75
*USED* Comp 921 Valve Spring kit, low mileage, comes will all Comp supplied hardware. Fits ALL LSX engines - $250 - This kit is $600 from Comp.
*USED* Z06/LS6 Casting 243 cylinder heads. These castings have the hard to find Z06 lightweight valves, also have a fresh set of PSI 1511ML springs on them (worth $200). Fits all LSX engines - $650 SHIPPED
*USED* Monster Billet Steel Flywheel, Fits LS1/LS2/LS6 engines, low mileage - $70
*USED* LS7 Aluminum Flywheel, Flywheel has been turned and ready for install. Fits all LS1/2/3/6/7 engines. Must have compatible LS7 clutch disk & PP to go with the flywheel - $150
*USED* Polyurethane motor mounts for C5 Corvette & LS1/2 GTO - $50
*USED* 2004 Corvette Z06/LS6 camshaft. Fits all pre-05 LSX engines. Low mileage - $200
*USED* 2 ASP under drive pulleys. Fits all 97-04 C5 Corvette and Pontiac G8's - $150/ea
*USED* JBA Longtube headers with flanges for 2008-2009 Pontiac G8. With fit both GT and GXP - $450
*USED* 2 Flowmaster American thunder 40 series mufflers for 1982-2002 Camaro/Firebird - $20/ea
*USED* 2 transmission coolers, both are low mileage with clean internals - $20/ea
*USED* LS3 Intake manifold with ported LS2/3 electronic throttle body. Fits all 2007+ LSX engines - $450 for the intake & ported TB
None of these listed are a beehive spring, but I actually have a set of PSI 1511ML beehive springs I could sell you for $100 shipped. They're a drop-in beehive that uses factory hardware, rated to .620 lift. Have about 5K miles on them. PM me if you're interested.
Interested in the 243's. Are they the later model heads with the triangle sand casting mark? Would love to see some pictures. Paypal ready.
Are you willing to sell without the springs? I'd need something with a little higher lift... Either way, please let me know via PM.
I wanna come blow my check there instead of at the retail outlets on BF O_O. I would LOVE to come pick up those heads, a cam, and springs, but I doubt I can convince my wife, if I can I'll be in touch, if not GLWS on all this awesome stuff
