tuned my car 200 shot stock long block video
Old 11-22-2013, 03:38 PM
vbls's Avatar
Default tuned my car 200 shot stock long block video
something was happening at about 6000 rpm right at the end of the video, could not figure it out.. its 133,000 mile stock long block car, spraying 200
Old 11-22-2013, 04:06 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Was it that inital bang or the popping at the end of the video you were referring to?
-Garrett
Old 11-22-2013, 04:09 PM
brandon@nitrousoutlet's Avatar
Looks like it hit pretty hard. Couple questions to help determine what that was around 6k.Do you have a copy of the dyno graph you can post here? How about some data logs? What type of system? Jet spread? Plug? Plug gap? Timing?What are you using to pull timing? Help me help you
Old 11-22-2013, 04:51 PM
vbls's Avatar
it wasn't the popping, it like surges, Im running b8efs at .032.
ill post the graph later.. I don't know the technical questions, my tuner did it
Old 11-22-2013, 05:00 PM
vbls's Avatar
my jets were 78/42
Old 11-22-2013, 05:10 PM
boostit5.3's Avatar
looked like a good hit then maybe hit the rev limiter at the end?
Old 11-22-2013, 09:20 PM
jblankenship's Avatar
Sounded like solenoids cutting on and off. Fuel pressure safety switch? Window switch? WOT switch?
Old 11-22-2013, 09:38 PM
vbls's Avatar
the solenoids are nitrous outlet, idont have a FPSS, and its a plate kit with a window switch that comes on and off from the WOT sensor
vbls's Avatar
and my tuner turned up the rev limiter
Old 11-23-2013, 02:30 AM
patrioticnova's Avatar
possibly window switch might be acting up..... other thing that can cause surging is running out of bottle pressure (bottle running out maybe?)... but sounds like you hit limiter.... it wasn't like a regular limiter cut off since it cuts fuel, but you have fuel that will still come in from the nitrous kit.....
Old 11-23-2013, 05:40 AM
vbls's Avatar
the window switch is a NOS brand, maybe ill see if theres a way to test it. wasn't the bottle pressure stayed ay 900 and I just filled it
Old 11-23-2013, 05:52 AM
Hit the rev limiter on motor to verify it goes higher than when that surging happened....
Old 11-23-2013, 10:37 AM
87silverbullet's Avatar
^^^What he said. Run it past 6000 rpms on the motor and see if it does the same thing.
Old 11-23-2013, 11:25 AM
ramairetransam's Avatar
ran out of fuel??
Old 11-23-2013, 08:28 PM
2 Stroke Racer's Avatar
What's your fuel system?
Old 11-27-2013, 03:25 PM
vbls's Avatar
stock injectors and racetronix pump
Old 11-27-2013, 03:53 PM
Can you post the dyno graph with the Air/Fuel chart as well?
Old 11-28-2013, 10:09 AM
vbls's Avatar
here is the dyno sheet
Attached Thumbnails tuned my car 200 shot stock long block video-dyno-sheet.jpg
Old 12-06-2013, 12:58 PM
Z284U2TRY's Avatar
Did the nitrous noid cut out?
Whats your timing?
I would guess you lost bottle psi car went fat and loading up on fuel.
Old 12-06-2013, 04:08 PM
vbls's Avatar
the solenoids are nitrous outlet and not old at all, they have never done that before. and I haven't changed anything since last tune
Quick Reply: tuned my car 200 shot stock long block video
