Change to low imp injectors?
Right now the 5.3 with the LS6 cam is idling pretty good (I think anyway) at about 750 with a PW of 1.4-1.5, DC = .5%, 31 kpa. This is w/o a trans hooked-up. My guess is that idle speed will have to go up when theres a trans/converter hooked-up.
It idles smooth with the "rough" tune. But hey, if it would be better with the low imp injectors why not!!!
Modern highZ's are better than old and generally most lowZ's in pretty much all respects
You should have no difficulty with a good set of 80lb highZ injectors.
Having said that my engine seems to have a smooth idle and is real responsive when winging the throttle. Don't think I can get it to idle lower than 750 - it gets rough under that.
Now Steve you realize this is the opposite of what I've been reading? Everything I've read states the low Z's out perform the highs everywhere. Unless what I'm reading is old info. I have Siemens 80lbs (actually Ford Racing) so I would imagine these are newer.
Back then it would have been almost unthinkable to have 2000cc injectors running an engine sweetly high or low. But today it is quite common and easy....only with highZ injectors.
HighZ has come on leaps and bounds. LowZ hasn't really moved at all.
I run low z 160's with the Holley HP EFI. It has taken a while but mine idles excellent. I idle mine around 950. I can run it lower I just prefer it at the rpm. You can hear the cam a little better with the higher idle. The Holley can run the low z's so that worked out perfect for me.
I have always heard that high z would be better if you can afford them. I couldn't.
