Axle Removal GM 7.5 10 Bolt
Old 11-29-2013, 09:09 PM
smitty2418's Avatar
Default Axle Removal GM 7.5 10 Bolt
So I am putting fresh bearings and shims in my 10 bolt since it has 4.11's I wanna make sure it is all snug and in the right position. I am having trouble getting the driver side axle out. I got the passenger side c clip out but the driver side axle just won't go in far enough for the c clip to fall off. Any suggestions?
Old 11-29-2013, 09:22 PM
jrpimp00's Avatar
Remove the Traction Control Sensor
Old 11-29-2013, 10:27 PM
GiggleJuiced_SS's Avatar
^ this. 10mm bolt and the wire connector.
Old 12-01-2013, 01:56 PM
smitty2418's Avatar
Thanks guys. Appreciate it. Haven't had a chance to go back out in the garage but I will do that.
Old 12-11-2013, 07:21 AM
smitty2418's Avatar
Just curious, how the hell do I remove the pinion nut if I already pulled the axles and driveshaft? I don't have access to an air tank or impact wrench. Car is on jack stands. Any advice would be awesome. Thanks.
Old 12-11-2013, 08:57 AM
96lt1m6's Avatar
You will need to hold the yoke in place... i made a template of the yoke face with 3/8 plate cut a 1-1/8" hole to access the nut and drilled 4 holes for the ujoint strap bolts then welded a 3' section of pipe to it so it could be held or wedged. At this point you get your 21mm socket and big ratchet out and get to work.
Old 12-11-2013, 09:39 AM
guppymech's Avatar
I used some bar stock I had laying around, drilled two holes in it to pick up a couple of the U-bolt holes. Ratech makes this nice yoke holder tool.
http://www.summitracing.com/parts/ra...FfBDMgod0XYA9w
Quick Reply: Axle Removal GM 7.5 10 Bolt
