New Procharger i-1 systems
http://www.procharger.com/i-1_corvette.shtml
anyone heard about these yet or seen them in action?
“You know you’re living in the 21st Century when ProCharger releases a touchscreen controlled, dry hybrid drive, programmable ratio supercharger that can make upwards of 850 hp and bolt-on to a variety of LS engines with ease. Programmable ratio means you can literally dial in the boost curve as you desire and can make boost adjustments on the fly using the digital touchscreen. Dropping your Camaro off with the valet? Turn the boost down to 1psi … Dropping it off at the track to get some killer times? Set it on kill, bring in the boost early, and get ready to hold on. Along with the new goodies, you’ll get everything in the kit you’re used to from ProCharger, which makes for a simple install and years of worry free driving.”
– GM High-Tech Performance, March 2013
