Racetronix fuel pump/hotwire install instructions????
I recently purchased a ractronix fuel pump/ hotwire kit for my 2001 Camaro from a member here on the forum. The only thing he didn't have was the directions to install it. Does anyone have the instructions that can email them to me?
Thanks
Thanks
I contacted them on here. They sent me a link to register for the racetronix forum. I tried registering, but I guess since I didn't buy the pump directly from them it's a problem to get registered. One of the admins pmed me and said he couldn't find me in their database for buying it from them. I explained that it was bout of tech, and all I need is directions. Haven't heard from them since.
Run the 10 gauge fused power line from the alternator down the frame rail following the brake line/fuel line to the rear of the car..
The relay will mount to the left of the fuel pump, just find any bolt in that area and hook the relay bracket to one of them..
Then unplug the bulkhead connector, you'll see plugged into the floor pan.. Then plug your connector into it and the plug you removed will now plug Into the other pigtail harness ..
Then your done..
Make sure the ground wire is grounded
Then your done..
Thanks
