3300HP LSX - Pro Line
The following 2 users liked this post by GeoMetricMoving:
lsoutlawz (10-24-2021), Salman Bakhit (12-12-2019)
Wild Azz LSX Engine!
GM LSX Iron Block
Sonny Bryant Billet Crankshaft
PLR Torrington Thrust Bearing
BME Aluminum Rods
Diamond Custom Pistons
Diamond Hard Anodized Coating
Total Seal Custom Ring Set
ACL/Calico Coated Performance Bearings
PLR Custom Camshaft
Jesel Tie Bar Lifters
Jesel Belt Drive and Front Mount Distributor w/ ICT
Dailey 5 Stage Dry Sump Oil Pump w/ Billet Pan
ATI Harmonic Balancer
MSD Crank Trigger
ATI Timing Pointer
MSD Plug Wires
MAST Mozez Canted Valve Cylinder Heads
PLR Head Gasket Sealing Rings
PAC Valvetrain Components
Smith Brothers Pushrods
T&D Shaft Mount Rocker System w/ Steel Rockers
Mast Billet Valve Covers
Hogan's Sheet Metal Intake Manifold w/ Billet Runners
ARP Hardware
Moroso Drive Mandrel Kit
Moroso Vacuum Pump
Powermaster Starter
ATI Flexplate
Dyno Tested to Ensure Optimum Performance
http://www.prolineracing.net/engines...x-mozez-3300hp
BME Aluminum Rods
PLR Custom Camshaft
MSD Crank Trigger
ATI Timing Pointer
MSD Plug Wires
ARP Hardware
Moroso Vacuum Pump
Powermaster Starter
ATI Flexplate
That's a lot of $$$$ for a 3000bhp LSX engine when compared to a 3000+bhp BBC from them:
http://www.prolineracing.net/engines...h-alum-3250-hp
Still fantastic piece though!
The following users liked this post:
Doug Williams (12-11-2019)
The following 2 users liked this post by 87silverbullet:
Doug Williams (12-11-2019), lsoutlawz (10-24-2021)
A lot of people dont understand what it ACTUALLY takes to build a motor to handle 2500hp.
You guys clearly don't know what it costs to build a motor like that. Like I said. That price tag is almost 20k too high.
Proline usually builds a great motor. However everything they build is 10-30% overpriced from the real world. You can't factor in "R&D". Hence why I said how much cheaper it would be to build. Their "R&D" is what makes them think their motors are worth that kinda money. And a lot of people need their "R&D"
And they must not have done too much "R&D" because an LSX block no matter what you do to it, its not going to like 3300hp.
I've had them split and crumble with much less than that.
