T6 Turbonetics 91mm/.96a/r Race Turbo to big for a 5.3?
Old 12-20-2013, 10:39 AM
Hulkls1's Avatar
Default T6 Turbonetics 91mm/.96a/r Race Turbo to big for a 5.3?
I can get a great deal on this turbo but do u think it will spool ok on the street I drive my car a lot and drag race it on weekends
Old 12-20-2013, 10:43 AM
trans2000am's Avatar
with the correct cam, converter ,gear and tune i would think you could make it work
Old 12-20-2013, 11:02 AM
Twin turbo c5's Avatar
I agree . I cant speak from personal experience with a t6 i've always run t4 flange turbo's on my 4.8's and 5.3's. I would run the numbers past jose at forced induction he could probaly go into more detail. With that 96ar exhaust housing I don't see why it wouldn't.
Old 12-20-2013, 11:14 AM
Hulkls1's Avatar
Ok I'll pm him and see I was going to go with a s475 96/1.32 ar but came across this
Old 12-20-2013, 11:34 AM
Go with the bw 475 that's a good choice that's what I have.
Old 12-20-2013, 11:39 AM
Hulkls1's Avatar
How does yours spool at the track?
Old 12-20-2013, 11:58 AM
It spools great it's a little laggy right off the bottom but my Fairmont has 273 gears and my converter isn't really setup to my liking. So I figure when I get a nice converter and a little more gearing it'll be on tha boost instantly. But it doesn't quit pulling on the big end with my current setup. You cant go wrong with that turbo.
Old 12-20-2013, 12:40 PM
Hulkls1's Avatar
Ok u sold me on it so yours is the 96mm 1.34 ar
Old 12-20-2013, 12:52 PM
No mine is t4 flange s475 with a 1.32ar 92mm wheel. There might be a better turbo for a 5.3 . I've always wanted to try a smaller ar on the exhaust side but i'm fixen to put this turbo on my 6.0 that it was originaly on.
Old 12-20-2013, 01:17 PM
Hulkls1's Avatar
Oh ok
Old 12-20-2013, 01:56 PM
i went with a large frame t6 turbo reason being im always changing things up and wanted to do the biggest turbo so i wouldnt have to change up hotside/coldside later down the road and plan on going bigger CI when my 370 goes kaboom
Old 12-20-2013, 02:06 PM
Forcefed86's Avatar
Go with the S475 83mm turbine 1.10ar T4. Works great in a 5.3. Went 8s in the 1/4 with mine with a jy 8.6:1 5.3.
Old 12-20-2013, 02:31 PM
I agree That's gonna be the turbo you need hulkls1. Mine works fine but could be better on my 5.3 but on my 370 that 1.32 housing is the ticket.
Old 12-20-2013, 03:35 PM
Hulkls1's Avatar
Ok thanks for the help . Got my car to run a 6.38 in the 1/8 mile with my ebay gt45 lol so my goal is to go high 5s this coming year and I want to up grade my turbo set up I have a stock 5.3 with zo6 cam all I'm going to do is get a custom cam and that s475 turbo hope it makes it in to the 5s with. Cam and new turbo
Old 12-20-2013, 03:38 PM
Awesome et with that gt45 You should meet your new goals with that s475 . goodluck keep us updated
Old 12-20-2013, 03:39 PM
Did you run that et on you old setup with a 5.3?
Old 12-20-2013, 09:44 PM
Hulkls1's Avatar
Yea I'm guy that builds my tranny said I got to step up to a 4l80e if I go any faster I have a 4l65e right now . With 3.73 gears . I ran that et on 28x10.5 slicks
Quick Reply: T6 Turbonetics 91mm/.96a/r Race Turbo to big for a 5.3?
