Nitrous wiring trans brake/ MSD 2 step
Old 12-21-2013, 06:08 PM
LsxBird's Avatar
Default Nitrous wiring trans brake/ MSD 2 step
Can anyone help me out with wiring? I used this diagram to hook up my nitrous kit worked how it was supposed too. Went 11.0 with the t56, help me bust some 10's with a th400, I need to add in a trans brake and msd 2 step. Wiring is not my thing. I have searched but its confusing for me. Thanks!
Old 12-21-2013, 08:07 PM
LsxBird's Avatar
Can someone add-on to that diagram for me? That would be very helpful.
Old 12-21-2013, 10:42 PM
FIVEPOINT7's Avatar
I could help with the brake, but I've never used a 2 step so I couldn't wire that.
Old 12-22-2013, 08:04 AM
LsxBird's Avatar
Thanks for the reply, the MSD is plug and play and there are two ways to activate it, a ground or a 12 volt source.
Old 12-22-2013, 11:12 AM
Chopstix's Avatar
go back to the same fquick site and find the diagram for the msd/trans brake
I have one listed that will work for you
Old 12-22-2013, 12:37 PM
LsxBird's Avatar
I think this is the right one. I'm just adding another relay(in-between the relay and WOT switch correct? and i can also add in the 2-step on the same power as the T-brake correct?
Thanks, your diagrams are amazing big help.
http://www.fquick.com/garages/viewga...wimg&id=139929
Old 12-22-2013, 12:47 PM
luigiandme's Avatar
1)So you want Nitrous/Window Switch and the 2-step to work with eachother EVERYTIME?
2)Or will you occasionally launch on nitrous without 2-step and/or launch on 2-step without nitrous?
If option 1, tap into the RED wire from the arming switch to MDS Window switch to supply power to the T-Brake relay or delay box and have the relay or delay box grounded by a momentary contact switch by your shifter, hand or steering wheel.
If option 2, wire the t-brake completely separate so you have the option to use with or without nitrous.
I hope that answered your question
Old 12-22-2013, 01:51 PM
LsxBird's Avatar
On that last link i posted with the diagram, wouldn't i be able to use the brake without nitrous the way thats wired up? Since its on its own power and switch? (couldn't i just turn off the nitrous and still use the brake) I don't think ill be using the brake without nitrous but i guess the option would be nice.
Old 12-22-2013, 02:03 PM
luigiandme's Avatar
Oh crap i didnt even see that link. Yea that would work. Just be sure to wire up the relay exactly as it says. 87a for the nitrous deactivation relay and 87 for the nitrous solenoid relay.
Old 12-22-2013, 02:47 PM
LsxBird's Avatar
Ahh good thing you mentioned that! I didn't catch it. ill have to use a 5 wire relay for that correct? this one here? and thanks for your help.
http://www.nitrousoutlet.com/electro...ans-brake.html
Old 12-23-2013, 09:38 AM
brandon@nitrousoutlet's Avatar
I emailed you a diagram.
Old 12-23-2013, 10:23 AM
LsxBird's Avatar
Awesome, thanks brandon!
Old 01-05-2014, 11:08 AM
v8sten's Avatar
this is my wiring diagram for my single stage kit with a transbrake
Quick Reply: Nitrous wiring trans brake/ MSD 2 step
