Nitrous wiring trans brake/ MSD 2 step
I think this is the right one. I'm just adding another relay(in-between the relay and WOT switch correct? and i can also add in the 2-step on the same power as the T-brake correct?
Thanks, your diagrams are amazing big help.
http://www.fquick.com/garages/viewga...wimg&id=139929
1)So you want Nitrous/Window Switch and the 2-step to work with eachother EVERYTIME?
2)Or will you occasionally launch on nitrous without 2-step and/or launch on 2-step without nitrous?
If option 1, tap into the RED wire from the arming switch to MDS Window switch to supply power to the T-Brake relay or delay box and have the relay or delay box grounded by a momentary contact switch by your shifter, hand or steering wheel.
If option 2, wire the t-brake completely separate so you have the option to use with or without nitrous.
I hope that answered your question
On that last link i posted with the diagram, wouldn't i be able to use the brake without nitrous the way thats wired up? Since its on its own power and switch? (couldn't i just turn off the nitrous and still use the brake) I don't think ill be using the brake without nitrous but i guess the option would be nice.
http://www.nitrousoutlet.com/electro...ans-brake.html
