Iron LS2 need more air?
I'm building a iron LS2 for my 2001 t/a the motors stats are in the sig for the 01 TA but it is as follows:
2011 ly6 6.0 iron block/LS2 flat tops/ 243 heads/ GM ASA cam/ TSP 17/8 LT's and ORY with borla catback. and a SLP blackwing lid and the stock LS6 intake.
With the above engine and mods and stock LS6 intake and blackwing lid will the stock TB and MAF be a limiting factor that needs to be upgraded or is it in a safezone to leave it as is.
I was thinking about jumping to the truck MAF but only if I need to.
This should be a fairly mild street driven motor that will never go to the track I'm not after dyno numbers but if stock parts are leaving a chunk of horsepower on the table I'll change them. (cam will not be swaped for other available cams)
