LS1 / LQ4 Alternator Question
Old 01-08-2014, 09:26 AM
N2Ojunky's Avatar
Question LS1 / LQ4 Alternator Question
Can you use a 6.0 truck 130amp alternator like for a 2000 2500hd on a 1998 z28 LS1 5.7? I need to replace mine and they are about the same price. The camaro alt. Is 105 amps the thr 2500hd is 130 amps.So I was just wondering if it would work.
Old 01-08-2014, 10:12 AM
Majestic9C1's Avatar
yes it bolts up fine.. you just wont be able to use the rear bracket..
Old 01-08-2014, 11:40 AM
N2Ojunky's Avatar
Thanks, I think I will go with the 130amp truck alt.
Old 01-08-2014, 10:29 PM
97camaro383's Avatar
I just did this mod on my TA. I got a alternator from a tahoe with the KG3 code 145amp, it plugged right in and was only 40 bucks.
Old 01-10-2014, 06:40 AM
N2Ojunky's Avatar
What is the purpose of the black plastic piece on the stock alt.? It almost looks like a vent maybe to deflect heat.
Old 01-11-2014, 02:49 AM
peacesells63's Avatar
I was looking at doing this on my 99 2500 4x4 since I built a dual electric fan setup for it. I was told you had to use a bigger charge wire to avoid burning the wire up at full draw.
Quick Reply: LS1 / LQ4 Alternator Question
