Muncie M20 Wide Ratio trans
Category: Drivetrain
Price: $900
Part Fits: Corvette, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): IL
Item Condition: Used
Engine: Small Block
LS Engine?: Non-LS Part
Numbers on the trans:
3884685 side cover- 66-67
3851326 front bearing cover- 65-67
3846429 rear housing , driver speedo- 63-65
3885010 case - 66-67
number at top of case- 7B108203
side of case P7R11- born on Oct 11 1967
Input shaft has 2 rings, 10 spline
output shaft dia is 1.188
passenger side drain
Gears and syncros look excellent. The gear oil is clean with no shavings. Was mounted to a 65-67 283
I drove the car maybe 500 miles since I bought it in September of this year. The shifter was a struggle at first; I sprayed the linkage and that helped quite a bit. I purchased a Competition Plus shifter but never installed it. Both will go with the trans, along with the boot and trim piece.
Muncie M20 trans/Hurst competition plus shifters
$900 OBO
