MSD or stock wires w headers.
Old 01-09-2014, 08:15 PM
01WS6/tamu's Avatar
Default MSD or stock wires w headers.
I've always ran MSD wires on my LS cars. But last year I bought a OEM set of plug wires for this car before I completely changed directions. Seeing as I'm putting TSP LT headers on it would it be better off or more reliable with MSD wires over the new OEM wire set.
Old 01-10-2014, 10:28 AM
It's not mine! woo hoo!
demonspeed's Avatar
I'd just run the OE wires until you need to replace them.
Old 01-19-2014, 11:33 AM
LilJayV10's Avatar
LS1Tech 10 Year
It depends on the design of the header. The MSD's are nice because you can bend the boots to keep it off the header. I had a set of old OBX(LPP) headers. I used the MSD's but still had two that got burnt.
Old 01-19-2014, 11:43 AM
ULTIMATEORANGESS's Avatar
Smile
if what you have is ok id stay with that for now.
Old 07-25-2014, 10:39 AM
PhoneniX's Avatar
I bought msd 32819, and advise against them. The coil side is angled but the plug side is a straight connector that runs directly into my hooker lt headers on the drivers side. there must be another part number where both ends are angled for clearance, but i have no luck finding mention of a optional wire set on msd's webpage. I'm planning on returning these for stock replacements again unless the connectors are truly bendable as mentioned above?? Can't dl the user guide online to confirm.
Old 07-25-2014, 11:07 AM
redbird555's Avatar
why not just bend the boots? they are bendable after all. mine would easily hit the headers if i didnt do so. op if you have stockers and they work then thats great. in my case my stockers were shot so i got the msd's which have been on 2 different sets of headers both times the bendable boots gave me the clearance
Old 07-25-2014, 11:41 AM
Majestic9C1's Avatar
I have MSD wires and I also have DEI spark plug wire sleeves over them
Old 07-25-2014, 11:44 AM
thunderstruck507's Avatar
the boots come straight but you can bend them
Old 07-25-2014, 04:20 PM
PhoneniX's Avatar
Thunderstruck/redbird: yep its confirmed by the technical support number, they bend and hold the angle. I also slipped the stock heat shields over the plug boot ends to be safe.
And now to get the thread back on track! As the o.p. asked any proof to better performance or reliability with the MSD parts? I can say that on the webpage I saw MSD sells direct replacement silicone boots for both ends. So future longevity would be better logically by replacing damaged boots.
Old 07-25-2014, 04:24 PM
revive a 6 month old discussion over wires lol.
Old 07-25-2014, 04:28 PM
Gray86hatch's Avatar
Stock or firecore50.
Cheap *** MSD imported junk. They were ok about 6 years ago but you install them more than 4 times and they don't snap on like they should.
Firecore50 good boots and snap on even after being installed 50 times.
Tim
Quick Reply: MSD or stock wires w headers.
