throttle body conversion help
I am currently running an 8 pin throttle body on my ls swapped truck, wanting to swap intakes over to where I can run the larger 87 mm 6 pin throttle body. Does anyone know if i wire the new pig tail up will the 6 pin throttle body work with my current pedal and tac module or am I going to have to swap some of those components out?
