Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Holley blue
Old 01-22-2014, 07:50 AM
Jesus Martinez's Avatar
Default Holley blue
Stock foxbody tank with holley blue pump how do I make this work a lot of guys are telling me I need a fuel cell?
Old 01-22-2014, 08:05 AM
In-Zane Moderator
ZONES89RS's Avatar
Replace the in tank pump with 3/8 fuel line. Mount the Holley below the bottom fuel tanks lowest level. It is a pusher not a puller.
Old 01-22-2014, 08:26 AM
Ok ima put an3/8 line with a lil screen in it but it will suck it trhu the top without a problem? Till atleast later down the road fuel cell comes in
Old 01-22-2014, 09:37 AM
punisher95's Avatar
HOLCOMB motorsports sell a adapter that fits in place of the pump assembly. has a "an" feed and return line hookup on top. i have used it with holley pumps....blue and black ones. works great and looks factory. cost about 100$
Old 01-22-2014, 01:33 PM
In-Zane Moderator
ZONES89RS's Avatar
It will pull done once it starts to get to pushing. Don't worry about a screen unless you have something that large that can block a 3/8 line. Otherwise a pre pump filter is what we all use.
Old 01-22-2014, 03:07 PM
It came with a regulator do I need a return bypass? Or I don't need to mess with none off that anymore
Old 01-25-2014, 07:58 PM
EastTnZ28's Avatar
Yes, this will work fine. Just block off one of the ports on the regulator cause you dont need a return.
Quick Reply: Holley blue
