Ls2 parts??
Old School Heavy
Then there is the square port cathedral port heads. The intake and intake valve rocker arms are unique to each design, so they have to be changed together.
Accessories you need to take as a set. Corvette, F body and truck all run the belt a different distance from the block. Iron blocks are missing some of the mounting bosses.
Computers are not interchangeable due in part to different number of teeth on the reluctor wheels.
Coil packs can differ different too and will have different connectors.
LS3 heads need a minimum bore size for valve clearance, so won't go on anything smaller than a 6.0L
Some of the trucks have slightly longer cranks, but can work with adapters
Big stuff typically swaps but lots of little differences here and there. It is not completely mix and match.
