Best lq9 cylinder head
For boost I would roll with LSA's because there decks are thicker and made out of stronger aluminum they cost a little more but IMO its worth it to not have to worry about lifting the heads. LS3/L92's seem to be hit or miss when it comes to boost, some people get away with them and dont lift the heads others have problems. From what I gather all it takes is a little bit of detonation and you will be changing head gaskets at the minimum with LS3/L92's, on the other hand LSA's take a little more abuse which makes them more reliable in a FI application.
You cant beat the flow out of the box of the rectangle ports though as far as bang for your buck.
