Is it acceptable to run the pcm and trans (4l60e) off one common fuse?
If so what amperage rating fuse would you suggest?
Laying out my fusebox plans right now and from what I gather some applications use a common pcm/ trans fuse and others use individual fuses.
Its a 99-02 pcm and a 4l60e.
Besides that I was planning on the following individual fused circuits.
*PCM constant +
*Left bank injectors and coils run/start +
*Right bank injectors and coils run/start +
*Left/ right front oxygen sensors and MAF run/start +
Planning on supplying all the above r/s + fuses via one bosch 30/40a relay.
Sounds right to me, what do you guys think?
*PCM constant +
