newb needs advice on his t56
So I'm swapping a ls/t56 in my 73 nova. Whole setup came out of an 02 camaro. I never got to drive it because the LS needs to be gone through, but the PO says the T56 is in great shape. Car had 120k miles on it and was bone stock.
My power plans for the swap include freshening up the LS1, adding a bigger cam, long tube headers, maybe a Bigger TB, and a tune.
My question is, since the T56 is out, should I go through and replace the bearings, seals, synchros? Is there anything that usually fails at this point? Or should I just run it?
Additionally, the PO said the clutch is a stock one and is brand new. Will a stock clutch handle the 400-450HP and 400ft-lbs tq I plan to put out?
Thanks guys.
Thanks guys.
As for the bearings, seals, & synchros somebody who is more knowledgeable then I am would have to comment. My T56 holds 400hp just fine so if it does shift fine you should be good. Again I am no expert.
However I would recommend going with an LS7 clutch. My LS1 clutch still had life in it but suffered when getting on it. Felt like a pig. One LS7 clutch later, it felt so much better. More reliable feeling IMO.
Hate to be the party pooper but if I was building a project car especially with a little more ***, and using a t56 with that many miles I'd have it gone through just because of the notorious 3-4 shift fork the LS t56 weakest link mine broke and not a fun day I didn't have 4th and third either popped out of gear or got stuck in gear when I tried to move it... Not a fun day... So if it was me I'd at least get the updated fork and new syncros and any other wear item inspected... Is hate for you to get it all together and get down the road 50 mi then have to tear it back down for something that could have been prevented... My sayn is pay now, or pay later... Pay now and get it looked at or pay later and roll the dice on pulling the tranny back out quite possible sooner than you'd want... But hey man either way just my two cents lol good luck to you and I'd love to see that kick *** retro nova on the street...
1. Can you refresh a T56 at home? Which are the necessary specialty tools?
2. About how much does a "kit" cost and what are the necessary items?
3. Any vendor recommendations?
Again thanks for all the help.
I can't help you there guy I'm a diesel technician with a camaro lol... There is a place tick performance check them out suppsto be really good with transmissions that's where I was gonna get mine rebuilt till I pulled the drain plug and clunk clunk clunk in the drain pan and no fluid came out until I poked though the metal shavings with a pick lol
i rebuilt my t56 at home with parts from tick. I did all new bearings and syncros. Some of the bearings do require either some really long pullers or a press though. But all the syncros are just a matter of pulling a few snap rings. The big thing is to either take pictures and keep everything in order or get a break down of the tranny like i did so i could see how everything went back together. I think i had close to 400$ in redoing mine(well worth it). My tranny had 100k on it and wouldnt allow me to downshift from 3rd to 2nd due to a broken snap ring inside.
