LSX nitrous build
Old 02-12-2014, 09:32 AM
BPlumCrazy-SS's Avatar
Default LSX nitrous build
I'm working on getting all of my information for a nitrous build. so what I would like to know is what size bore is everyone using on there LSX block.
Old 02-12-2014, 05:55 PM
LSFreak13's Avatar
Correct me if I'm wrong but I'm pretty sure you can spray stock ls motors.
Old 02-12-2014, 08:07 PM
Oh you can but not what I want to spray..... I'm doing a 2 stage kit 150 and 350-400
Old 02-26-2014, 03:49 AM
DREAMZ28's Avatar
Might want to post over on the yellow bullet forum, not too many people here spray that much
Old 02-26-2014, 12:02 PM
bmeyer40's Avatar
Turbobullet is another good spot for big spray builds
Old 02-26-2014, 12:23 PM
ATVracr's Avatar
Sprayed 400+ LOTS of times on our stock iron block set ups.
Its all in the tune up.
Old 02-26-2014, 12:26 PM
87silverbullet's Avatar
In the nitrous world, build the biggest engine you can afford to build that is nitrous friendly and then cam and head it accordingly. make sure you get some gas ported pistons with a good compression height and keep some meat in the cylinder walls. Talk with Kurt Urban or Billy Briggs or LME can get you lined up in the right direction. I would say to take the motor out to 4.155 and use a 4.125 crank and you can come out with a 445 cu in motor. You can play around with your cubes with bore and stroke. I like to keep some meat on the walls hence why I used a 4.155 bore. You can go bigger though.
Quick Reply: LSX nitrous build
