Aes 390 / F1A results?
Old 02-23-2014, 08:15 PM
Tirefire's Avatar
Default Aes 390 / F1A results?
Alright I'll start by saying I wasnt very happy with the results. Current set-up is an AES 390 with an F1A (3.90 pulley), Brute speed cam, tfs 220 heads and ls6 intake. Fastest run of the night was 131 mph using bfg dr's that was with 12 lbs of boost. I have the small hat on ill be changing it the next time I go to the track. I did see belt slip with the Aster Bracket and I believe because its not truly aligned correctly. Aside from these issues how fast can this setup go? I was hoping to be in the 145's mph is that wishful thinking for 4000 pound ta with me in it? Oh its a 6 speed..Any help appreciated. Thanks
Old 02-23-2014, 08:24 PM
I8UR4RD's Avatar
without and videos, timeslips, dyno graphs, tuning information....its really hard to just tell you why its down on ET, but I can tell you I expect mine to run an 8.xx sometime this year. @150mph or so.
Old 02-23-2014, 08:39 PM
Tirefire's Avatar
No dyno chart my 1/8th was 102 mph. How much boost should I be expecting with a.3.90 pulley. I did see about 15 lbs but that was at 7400 rpms but that was not at the track.
Old 02-23-2014, 08:49 PM
I8UR4RD's Avatar
7400 rpm? that thing quit making power long ago. you prob needed to shift at 6500-6700. unless your running a pro flo or vic jr i have been told that the ls6/plastic intakes generally make power in that area. if your making 15lbs that sounds about right.
102mph is very low. I would like to know who is tuning the car. of course it being 6 speed hurts but that is still a really big gap. at 15 lbs that thing has to be making a MINIMUM of 800 hp if tuned right. an 800 hp car will trap higher than that blower the tires off.
Old 02-23-2014, 08:59 PM
Tirefire's Avatar
Its definitely not my tuner he's solid. What about the cam do you think I can go bigger or is that good enough to trap in the 140's?
Old 02-23-2014, 09:08 PM
Tirefire's Avatar
I hope Bob comes in and chimes in. I want to see how much boost and mph he was making with his old setup from exotic performance.
Old 02-23-2014, 09:13 PM
haulass350's Avatar
this should be interesting i've got an AES 390 and a F1a coming in a 4200lb truck lol
Old 02-23-2014, 09:25 PM
Mike 02T/A's Avatar
Something doesn't sound right. I'm trapping around 143-144 and I've got the F1A w/ 5.25 inch pulley. That's with AFR 225 heads, same cam, TSP headers and rod bolts.
I did just switch to a FTI TH400 though and I'm running meth (Alky Control kit). Maybe there's a boost leak somehwere!
Old 02-23-2014, 09:26 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Sorry Andy, I've been watching the Daytona 500. We were seeing 18 to 20 psi of boost with my 408 with the 7.65/3.90 blower pulley at 6600 to 6800 rpm. KP was running 8.80/8.90 at 150+ with my cam and an F-1A. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 02-23-2014, 09:32 PM
Tirefire's Avatar
Something is always wrong with my s$&t!! Elevation maybe? Im at 3800 ft would that be some of my issues?
BTLBABY's Avatar
What gear is in the car? What kind of inner cooler set up? What injector size?
Old 02-23-2014, 09:36 PM
Tirefire's Avatar
[QUOTE=BTLBABY;18041758]What gear is in the car? What kind of inner cooler set up? What injector size]
Gears are 370's its a 9 inch got from Bob. I have 80 lb injectors going to 127 after seeing my logs yesterday (98%)
Old 02-23-2014, 09:37 PM
Tirefire's Avatar
When I saw 15 lbs injectors were at 115%
Old 02-23-2014, 09:40 PM
BTLBABY's Avatar
Yep, def need bigger sticks.
What about the I/C set up? What kind of IATs were you seeing? What size tire you running?
What ET did the car go?
Old 02-23-2014, 10:02 PM
js2fst's Avatar
Is fuel pressure boost referenced? I have been wondering about my 80 lbs injectors I got a 408 similar to bobs I am thinking a f1-a
Old 02-23-2014, 10:07 PM
Tirefire's Avatar
Iat intercooler, I have alky so I saw iat in the 60's from 115. 28 inch tire and 131 mph. Fuel pressure is boost referenced
Old 02-23-2014, 10:16 PM
BTLBABY's Avatar
A 28" tire with a 370 gear is actually like running a 350ish gear. So couple that with a 6spd, you're pushing more gear then you would think.
I bet you're barely getting into 4th gear before the traps.
Old 02-23-2014, 10:27 PM
Tirefire's Avatar
Im at 6550 rpms at the end of my run. Only seeing 12 lb of boost
Old 02-23-2014, 10:29 PM
BTLBABY's Avatar
What's your shift RPM?
Old 02-23-2014, 11:40 PM
+badss+'s Avatar
To give you an ideal I'm at around 3850 w/driver and I trapped 112mph in 1/8 and 140.47 in 1/2 mile making 15 lbs of boost
3.73 gears and 28" tall drag radial I'm auto tho.
Quick Reply: Aes 390 / F1A results?
