Nitrous wet plate???
Old 03-10-2014, 12:48 AM
dustind6327's Avatar
Default Nitrous wet plate???
I have a 01 trans am with 92/92 fast intake and fast throttle body which plate do I need from nitrous outlet?? Link..
Old 03-10-2014, 08:01 AM
Rise of the Phoenix's Avatar
Nitrous Outlet 92mm plate kit.
Old 03-10-2014, 10:39 AM
02streetsweeperSS's Avatar
http://www.nitrousoutlet.com/efi-wet...te-system.html
Old 03-10-2014, 11:38 AM
brandon@nitrousoutlet's Avatar
http://www.nitrousoutlet.com/nitrous...tallation.html Here's the plate by itself if you would prefer that.
Old 03-10-2014, 02:54 PM
I'll need the whole kit but what's the difference in the 92mm lsx wet kit and the 92mm fbody wet kit??
http://www.nitrousoutlet.com/efi-wet-nitrous-systems/gm-systems/nitrous-outlet-92mm-lsx-plate-system.html
http://www.nitrousoutlet.com/efi-wet-nitrous-systems/gm-systems/nitrous-outlet-92mm-fast-intake-98-02-f-body-plate-system.html
Old 03-10-2014, 03:04 PM
high impact's Avatar
Email Brandon and he will take great care of you. I just upgraded my plate kit from a 90mm to a 102mm. Nitrous Outlet is great to deal with!
Old 03-10-2014, 03:19 PM
Pretty sure the F-Body specific kit has the hard lines that go from the noids to the plate and the non F-Body kit does not (they are the braided lines). The F-Body kit also has the specific mounting brackets for the noids that attach to the fuel rail. You can see it in the pictures if you look closely.
Old 03-10-2014, 03:20 PM
One is fbody specific and has hard lines from the solenoids to the plate and a specific fuel rail adapter with a hard line coming from it to the fuel solenoid.
The LSX 92mm system has universal solenoid brackets and braided lines.
Old 03-10-2014, 04:00 PM
I have stock fuel rails but the fast 92 intake and throttle body so which kit is the one I need?
Old 03-10-2014, 05:13 PM
00-10118-92-10 is the part number you will want.
Old 03-10-2014, 06:21 PM
Does that kit perfectly or do I need to drill, cut, modify ...ect ect
Old 03-11-2014, 08:46 AM
The vehicle specific systems are made so that you don't have to modify anything. You could take the system off and not even know it was there.
Quick Reply: Nitrous wet plate???
