Old 05-05-2016, 06:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Electrical Guides
Browse all: Electrical Guides
Print Wikipost
not charging battery
Old 03-10-2014, 04:57 PM
ryadew3468's Avatar
Default not charging battery
My voltage gauge reads right under the beginning of the red line. I have had my alternator checked a few times and also replaces the plug that connects to the alt. Any idea what else i should check? thanks for the input.
Old 03-10-2014, 05:03 PM
nitrous2fast's Avatar
Battery....
Old 03-10-2014, 05:08 PM
ryadew3468's Avatar
Originally Posted by nitrous2fast
Battery....
its a dec 2012 battery....i guess ill get it tested to be sure.
Old 03-10-2014, 06:40 PM
jaycenk's Avatar
Is the Alt original? It could be a bad regulator if the Batt will hold a charge.
Old 03-11-2014, 08:07 PM
ryadew3468's Avatar
Original to me. The regulator is inside the alt, correct? Thats what the plug on the back side of the alt is for? Or soni assumed.
Old 03-11-2014, 09:36 PM
shbox's Avatar
If there isn't any power going to the little wire that plugs into the alternator, it won't charge.
Old 03-12-2014, 10:06 AM
ryadew3468's Avatar
Ill get a multi meter on it to check.
Old 03-12-2014, 10:39 AM
Village Troll
SS RRR's Avatar
^^^ And it should read a consistent voltage of around 14.5 volts. If it fluctuates then most likely the alt. is bad.
Quick Reply: not charging battery
