How to fix sideview mirrors that are powered? They just stopped working.
Ungrounded Moderator
The power mirrors are protected by 15A fuse #7 labeled PWR ACCY.
Never rely on a visual inspection of a fuse (especially an old fuse)... it can look fine but still be blown. Always use a fuse tester or multimeter to test or replace with a known good fuse.
However, if one went out before the other, it's not going to be the fuse - both are on the same fuse. It's probably the mirror motor itself although it might be the switch.
