FS: 1998 Formula WS-6 Single Turbo Street/Strip CLEAN
Year: 1998
Make: Pontiac
Model: Firebird
Price: $35000
Mileage: 80000
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Run down..
Strange 9 inch, shortened 1.5 inches on each side, slightly tubbed to fit 15x12
Th-400
10 pt cage (out of date)
Wolfe Sub Frames
Wolfe Low control arms
Wolfe Torque Arm (long one)
Wolfe Anti Roll Bar
Afco rear shocks
Strange Front Shocks
K member/ A Arms, All painted black
All NEW ball joints, tie rods ( there isnt a bolt that isnt new)
Strange Brakes all the way Around
Corbeau Seats with 5 pt harnesses
All gauges in the heater vents (Interior is near flawless)
Hydraulic roller, Air to Air intercooler. It is tuned for 110 out of the pump octane.
Engine has maybe 75 street miles, and a hand full of 1/8th mile passes.. (i have other cars i race). The car has 3 settings on the boost controller. Has never been on the highest setting, i had the car at the track just dialing in the suspension on the lowest boost setting once and had a race the next track outing. Check the video posted below.
KFP Racing built the engine and turbo kit, (Dr. Phil) Phil Hoefler tuned the car.
NO EXPENSE SPARED on engine, or anything on the car. No corners cut, and this was a very well thought out car. I built the car to be street driven, street raced and taken to the track. All signals work, still retains stock original WS6 Hood, no weight taken out.
UNDERNEATH HOOD is FLAWLESS, whole turbo kit is polished, custom valve covers and could be a show car. Bottom of car is very clean and under hood is mint. Must see to appreciate.
Custom Radiator, the car could go rounds and wont go over 170 degrees. As a matter of fact i never seen it over 158. Trans temps, never over 140.. Does have a huge trans cooler up front.
I am probably forgetting a ton of stuff, car needs absolutely nothing.. And i am sure the car is faster than you think. $35,000 OBO
I wasnt out much last year due to work, but here is The one race i had..
