Gas line
Old 03-16-2014, 08:54 PM
transwiz's Avatar
Default Gas line
I changed my fuel filter and the fitting with quick connect made a noise when I removed the filter like it broke internally.I started the car and it seems to be allright and not leak but I don't trust it.I thought I would replace the line. This is the one that goes from the fuel filter to the fuel pump.
Can you replace it with gas line hose and clamps or do you have to replace it with the original line?I did the trap door mod the other month when I replaced the fuel pump assembly. How hard is it to replace that line? I hope I can do it without dropping the tank.
Old 03-18-2014, 03:37 AM
transwiz's Avatar
Someone must have replaced that gas line.
Quick Reply: Gas line
